TH-350 vs Turvo 400
I'm by no means a trans expert but from past experience with 350's I would
go with the 400 . I have one in my coupe and although no where near the HP you have, it came out of a 79 Grumman step van "disassembled / inspected " slid it in and have no worries when going anywhere .with an adjustable vac. modulator you can fine tune your shift points to your needs. They take a bit more HP to run but they are tough. I have never had a 400 fail me (350's & 4L60E's, thats another story). There are members in this forum that can better address your needs, it's the holiday weekend but I'm sure they will reply. Good luck |
How long your t-350 lasts with an honest 550 hp big block will depend on 2 things : the current condition of the t-350 and how much traction you have. IF you have traction , the t-350 trannys life will be short even with a 3.00 gear The stock converter will not function well I imagine . The camshaft to get 550 hp from the engine would require an upgraded converter. good luck
At the Bonneville Salt Flats, first gear is known as 130 mph. |
and get one. just don't run the adjuster past the thread end . I'm sure they are also for the 350. |
A th350 trans can be beefed up to handle a high output BBC. However, a stocker will not last very long. Hard to say without knowing the condition of the trans and your driving style. But a good condition th350 should last a summer of some abuse. Installing a shift kit could extend the life by reducing slippage.
400's can do very well in stock from with just a shift kit and a governor adjustment for higher rpm shifts. Plus there isn't that pain in the butt down shift cable on a 400, it is electrical. So, I prefer 400's behind high powered engines because they hold up with just a stock rebuild and a shift kit. A 550 hp BBC with have a hard time launching a 74 Nova with a stock converter and 3.08 gear. Don't except any wheel stands with that combo. A 3.55 gear and a 2600 stall should be the minimum with that setup. |
This may help with the 10 bolt rear ID.
http://chevyhiperformance.com/techarticles/49998/ A shift kit will make the transmission shift faster. This reduces clutch slippage and wear. A shift kit can be installed with the transmission in the car. How fast is the trans shifting now? |
go with the 400
I'd definitely go with the 400, but you need to ask yourself this.. do you want to be able to sell the 350 for a few bucks??? if you drive it until it blows.. most people are looking for drop in and drive... if youre not concerned with reselling.. i'd do a little experiment have some "FUN" and see what the o'l 350 can handle until it goes tango uniform..
thanks for the tip.
I will do as you say and run the TH-350 this upcoming summer, then probably go with a Turbo 400. I almost have the car ready after doing some under the hood upgrades this winter. Next winter is when I plan on doing the drivetrain and want to prepare myself and have a plan so that when october 2006 arrives I'm ready to go to work. I would like to sell the TH-350 if I can - why not, but I don't expect to get much for it. If I get $100 that would be great. Is that possible? I can't sell it on ebay because the shipping would cost more than the thing is worth. Maybe a local trans shop would give me some cash for it. |
Selling
you can brobably sell it for the most on craigslist.. plus you dont get charged a fee to post the ad.. and... the people replying are local.. so they will pick it up...
| Turbo vs Supercharger - Write up!! | FastChevyTruck | Engine | 107 | 02-16-2011 12:18 PM |
| turbo 400 with deep pan | orangecrush | Transmission - Rearend | 8 | 12-15-2005 03:46 PM |
| 700r4 Swap to a Turbo 350 | humanVr4 | Transmission - Rearend | 23 | 08-02-2004 07:48 AM |
| Broken 400 SBC flexplate with a 350 block... | realsquash | Engine | 5 | 04-20-2004 11:23 AM |
| turbo 350 | Tissue | Engine | 3 | 04-09-2004 07:05 PM |
