TH 350 won't access forward gears
Okay so I have a 1971 Buick Skylark with a 350 trans and 350 motor. The transmission worked beautifully until i had recently installed a B & M shift improvement kit to the street/strip setting in attempt to lower my e/t.
After installing the kit i was extremely satisfied with the results, the shifts were firm and the tires would chirp under WOT, until recently. After a few days my transmission began slipping in forward gears more and more, now i can only access Park, Reverse, and Neutral, when i try to engage Drive, Second, and First nothing happens. If anyone has any idea what could be causing this i would appreciate your input. Thanks |
Does the vehicle move forward in manual first gear?
IF not... i suspect the forward clutch is burned out. What was the age - condition - mileage on the trans before the SK was installed??
At the Bonneville Salt Flats, first gear is known as 130 mph. |
The vehicle does not move forward in manual first gear either.
I believe the transmission is original to the vehicle, which means its from 1971, The transmission was in good working condition before the kit, i really never had any problems with it until this. The transmission has roughly 150 thousand miles on. If it is the foreword clutches, would it be easy to repair? Thanks |
It would have to be rebuilt at this point. If you're handy ,you could do it yourself.
| Why not a 350 sbc? | bowtieorbust | Engine | 29 | 09-05-2008 09:43 AM |
| possible 350 block purchase - comments please | idrva55 | Engine | 17 | 12-09-2007 09:29 PM |
| 350 price? | hcker2000 | Engine | 4 | 08-02-2004 12:48 PM |
| TH 350 no forward no reverse | joesnova2 | Transmission - Rearend | 4 | 05-14-2004 10:48 PM |
| 350 no gears | molevolent_creations | Transmission - Rearend | 1 | 02-25-2004 07:41 AM |
