th 350c lockup question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-02-2003, 09:24 AM
74huggerorange's Avatar
Post th 350c lockup question
When the converter in a th350c locks up how many rpm's does the engine drop? Thanks
Old 04-02-2003, 04:44 PM
BOBCRMAN@aol.com's Avatar
Post
it depends on many factors, how much load is on motor at the time, road speed, engine size,wind direction,altitude,temp,etc.
Old 04-02-2003, 05:07 PM
airworld2's Avatar
Post
typically rpm drop 150 to 300 rpm in lock up depends on stall of torq converter
[ April 02, 2003: Message edited by: airworld2 ]</p>
airworld2
Old 04-03-2003, 05:20 PM
Post
This transmission is in a 74 chevy pickup. It is out of a 84 chevy pickup. Over a year ago I had the lockup converter hooked up to a toggle switch to make it work and it worked well. Today I went to hook it up again and I couldn't get it to work. What are these 2 wires and what needs to be done to get it to work again? thanks guys
