th 400 1-2 upshift w/lever in 1st - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2011, 04:15 PM
this is in a offroad vehicle.when i shift to 1st and give it more throttle,it shifts on up to 2nd. also this tranny does not have a kickdown switch or cable.i run a 351w with a c6.but a couple of friends use the th 400 and have ask me about this.is there a kit or procedure to fix this.will not stay in 1st. thanks
Old 07-04-2011, 04:32 PM
SSedan64's Avatar
The fix is found here>> http://www.crankshaftcoalition.com/w...tomatic_shifts
http://www.crankshaftcoalition.com/w...0_Rebuild_tech
Old 07-04-2011, 04:33 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You need to grind flats on the 1-2 shift valve. There are instructions for this on the net, they say to also plug an exhaust port in the VB- something I never did when I modded my valve.
Name:	TH400 1-2 SHIFT VALVE MOD.jpg
Old 07-05-2011, 09:38 AM
thanks to everyone,that's just what they needed
727-b no 2-3 upshift,no 3rd ratlover Transmission - Rearend 2 06-21-2009 07:23 PM
727 will not upshift CedargroveUSA Transmission - Rearend 5 03-13-2007 10:10 AM
no upshift oldsmo Transmission - Rearend 1 02-18-2007 08:17 AM
Convert multi-function signal lever to plain lever? murrsue General Rodding Tech 0 03-07-2005 07:56 PM
no upshift on the pg Mr.Misfit Transmission - Rearend 9 02-18-2005 10:07 AM
