th 400 downshift help - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2005, 06:17 PM
i was wondering if anyone out there knows how the electronic downshift looks like and the set up.It would be helpful to find a diagram. My cousin had the car and took it all apart and dose not remember how it was all set up. I am working on a 1970 chevelle with a 454. If anyone can help me out that would be great. Thanks for your help it is much appreciated.
Old 11-18-2005, 09:32 PM
sedan delivery's Avatar
shift linkage
log on to autozone
fill in information of your veh.
go to repair information
go to drive train
go to transmission adjustments
scroll to the bottom of the page for information and description
you can also go to the public library and find repair manuals
Old 11-19-2005, 10:46 PM
On the f-body, 12 volts goes into the kickdown switch. The other side of the switch connects to the transmission solenoid. The other side of the solenoid is grounded.
When you accelerate WOT, the switch closes sending 12 volts to operate the solenoid. That alters fluid flow in the transmission cause downshift.
The kickdown switch is mounted with the carburetor, driver's side mounted on its own bracket. Chevelle is likely to be similar.
You should find two slide on connectors for the switch and one slide on connector at the driver's side of the transmission at the back.
Ok, here's the debate of the century: 383 or 400 chevy!! Cast your vote and reason killerformula Engine 303 03-28-2013 08:08 PM
400 Combinations MI2600 Engine 15 05-12-2006 07:08 PM
chevy 400 buildup 406chevelle Engine 15 06-08-2003 03:41 PM
400 327 crank limey Engine 8 09-24-2002 07:53 AM
Small Block 400 chevyelc81 Engine 9 06-18-2002 06:10 PM
