Your welcome! And if I'm not mistaken,the next time you have the pan off of your trans. , you can double check your dipstick by marking a line on your dipstick even with the bottom of the trans. where the pan bolts to it...(make sure to leave the dipstick in the dipstick tube)
with a OEM converter and stock pan and cooling, 11 1/2-12. with deep pan and aux. cooler, up to around 13 1/2 total. (can be more with the aftermarket billet pans that are available now days) smaller high stall converters (under 12") will take less fluid anywhere from 2-3 qts. |
Thanks to all who replied. I have it filled correctly and apparently have another issue (manual shifting) unrelated to the fluid.
Jakeshoe recommended checking the line pressure, but I am not sure how to do that yet. |
There's an 1/8" Pipe Plug on the Driver side a few inches above the Pan rail, about middle of Pan. You'll need a Gauge with at least 0-200psi. range.
("Brakes Applied"):---------- Normal Psi. Neutral @1000rpm-------- = 55-70psi. Drive @Idle speed-------- = 60-85psi. Drive- @1000rpm--------- = 60-90psi. Drive-2 @1000rpm-------- = 135-160psi. Reverse @1000rpm-------- = 95-150psi. Drive @1000rpm, w/Downshift Solenoid On-- = 90-110psi. Pr. Test Kit >> http://www.sjdiscounttools.com/atd-5550.html Capacity chart >> http://www.tciauto.com/tc/fluid-capacity |
Where are the psi ratings from? Is it in a manual that I should obtain?
ASTG Manual for TH400/3L80 for Overhaul/Rebuild.
http://www.amazon.com/Techtran-Manua.../dp/B000HZTJ9G |
| fluid capacity | helrazr3 | Transmission - Rearend | 5 | 11-30-2010 09:59 AM |
| fluid capacity??????? | 4dr77impala | Transmission - Rearend | 2 | 07-10-2007 08:34 PM |
| M21 fluid capacity | mrl | Transmission - Rearend | 3 | 01-10-2007 01:02 PM |
| TH350 fluid capacity | big455 | Transmission - Rearend | 5 | 06-27-2003 10:02 AM |
| fluid capacity for 350 turbo | mtmniles | Transmission - Rearend | 2 | 04-04-2003 05:01 PM |
