th 400 kick down - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-06-2005, 07:17 AM
th 400 kick down
i was wondering if anyone knew how the kick down mechinism work and looked like on a the 400 on a 1970 chevelle thank you
Old 11-06-2005, 07:56 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
IF I remember , these cars had a switch attached to the gas pedal bracket under the dash on the firewall. The throttle arm moved the switch with direct contact
Ok, here's the debate of the century: 383 or 400 chevy!! Cast your vote and reason killerformula Engine 303 03-28-2013 08:08 PM
400 Combinations MI2600 Engine 15 05-12-2006 07:08 PM
chevy 400 buildup 406chevelle Engine 15 06-08-2003 03:41 PM
400 327 crank limey Engine 8 09-24-2002 07:53 AM
Small Block 400 chevyelc81 Engine 9 06-18-2002 06:10 PM
