Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - TH 400 low gear conversion
Old 09-04-2006, 03:36 PM
runn141's Avatar
runn141 runn141 is offline
Originally Posted by jakeshoe
Crosley works at Hughes so I'm sure they make or market some different gearsets.
Kilgore is def an innovator in the TH400 world.
I like Chris at CKPerofrmance for his custom parts, although I haven't used any of the low gearsets for a 400 yet.
My understanding is that you use parts from the lower geared 700 or 4L60 planets to make the low (2.75) gearset for a TH350. You could also reverse this and make a shallower gearset for the 700, Chris makes a 2.66 first gear ratio for the 700 IIRC.
That would be a pretty good gearset in the 700.
does it matter what spline the 700r4 is 27 or 30? and wouldnt it be a 3.06 ratio? or is it some of the sun gears you change?
