TH 400 low gear conversion - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-04-2006, 04:43 PM
jakeshoe's Avatar
Spline doesn't matter, it is the low planets that you use.
You would use the pinion gears from the 700 and have a custom sun gear made.
You have two sets of planets in the TH350 and TH400. The planets in a 700 are very similar to a TH350, basically the same design but with different gearing.
You would use the 700 pinions and output ring gear, but the sun gear would have to be half 700, half TH350.
You would also have to do some fancy work on the ring gear since the output shaft is attached differently in the TH350 and 700.
Disclaimer,
I haven't actually done this, as in made a set. I am going on what I was told by another trans guy who does make these setups using the parts mentioned and a lathe, welder, etc.
My info could be incorrect or incomplete.
  #17 (permalink)
Old 09-05-2006, 09:34 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
wow, what a group of information flying around.
  #18 (permalink)
Old 09-06-2006, 05:08 PM
Jeeper426's Avatar
Automotive LTD Technition
waow, i didnt realise that there was so much to a TH350 and TH400, i'll definately ask you guys before i do any mods involving a tranny seeing as i'm kinda' a Noob when it comes to transmissions, and i was looking in the wrong column when i typed that thanks for clearing that up for me
TH350 to TURBO 400 CONVERSION leejoy Transmission - Rearend 5 01-24-2006 12:09 AM
7 hours, 33 phone calls, &30 pages of Threads later... Rearend? Tranny? Need Guidance 68ChevelleFromHell Suspension - Brakes - Steering 19 01-13-2006 01:01 PM
BBC cam gear problem 454C10 Engine 4 12-14-2004 02:07 PM
More TECH On FORD Dist. Gear Failure KULTULZ Engine 8 03-18-2003 04:50 AM
Speedometer Gear Change ? bigjoedo Transmission - Rearend 3 07-04-2002 06:52 PM
