th 400 ? output shaft - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-27-2005, 01:17 PM
have a van trans with a bolt on yoke need to install a slip yoke is this possible without internal work
Old 09-27-2005, 08:54 PM
Crosley's Avatar
Wiki Edits: 1659
yes,
short style slip yoke fits onto all the shaft splines.
It is best to pull the tail housing off to see how / where the slip yoke hits the groove on the output shaft where an O-ring fits for the bolt on yoke...
simple , simple , deal
Old 09-27-2005, 10:33 PM
ok cool thanks 1 more ? the down shift wiring i think where would that get powered from th400 are new to me i ran a glide or a stick so any help would be great thanks ken
Old 09-28-2005, 09:09 PM
Crosley's Avatar
Wiki Edits: 1659
12 volts is needed for down shift hook up.
Factory used a switch at the carb in early years , then a switch at the gas pedal on inside of the firewall in later years.
The switches were a sliding type that could activate at about 3/4 throttle and still allow full throttle ... un like a simple on/off push button switch.
Some guys have used an older motorcycle stop light switch with a spring on it , hooked to the carb.
You can drive the vehicle/ t-400 tranny fine with the power unhooked.
Old 09-29-2005, 06:44 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
Like Crosley stated, along with the later fuel injected engines using the ECM to activate the circuit.
Tubro 400 tailshaft &drive shaft Problem MAD BOWTIE Transmission - Rearend 11 06-19-2005 11:51 PM
727 output shaft spline fat50 Transmission - Rearend 4 10-05-2004 06:49 AM
transmission 700r4 output shaft slop catscan4free Transmission - Rearend 3 01-25-2004 08:11 AM
AOD REAR OUTPUT shaft, buSHING buckhorn Transmission - Rearend 5 10-26-2003 10:00 PM
output shaft to slip yoke vader Transmission - Rearend 1 03-28-2002 09:31 PM
