Th 400 question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-07-2009, 02:49 PM
Icelander's Avatar
Th 400 question
Hi guys, about one year ago i bought from Summit a th 400. the one they sell under they're own name, any way i just installed it in my brothers 396 Nova and it feels lazy when shifting in 3rd gear, almost slips ! ? and another thing when i put in i 1st. manually it feels like it comes very heavy ? i mean if i accelerate the engine the rpm goes up but the car does not move freely like in drive. What i am saying is that if i put it in drive and let go of the brake the car starts to move but not when i put it in 1st. I have tried to disconnect the shifter cable and set the lever in 1st position by hand and no difference ?
Any ideas ? Anyone please !!
Thanks in advance and best regards. Kristofer
Old 09-07-2009, 05:49 PM
S10 Racer's Avatar
http://www.warsprints.com
Check the fluid level when hot.
Does the tranny have a modulator valve on it? Do you have vacuum to it?
Are you sure the tranny did not come with a reverse manual valve body? If it did, 1st gear is actually 3rd.
Old 09-07-2009, 06:07 PM
Icelander's Avatar
Hi, yes it has modulator and i have vacuum hose connected. About the valve body i can set it in drive and then it works OK. takes off in 1st. gear and shifts up beside that it is rather lumpy when hitting 3rd. I can set it in 2nd. and then it starts in 1st.also, and when i start in 2nd. and release the brake the car runs and if i then set it in 1st. its just like i step on the break and the car stops ?
Thanks for your reply. Kristofer
Old 09-08-2009, 05:56 AM
SSedan64's Avatar
This is from the TH350 manual, may apply to the TH400, Crosley would know more. >> http://th350.netfirms.com/pages/7a2-09.jpg
SBC Question 400 block Jag Daddy Engine 41 06-18-2007 08:31 PM
400 SBC timing question JohnyR17 Engine 24 05-20-2007 09:13 AM
65 skylark turbo 400 trans. install question skylark65 Transmission - Rearend 7 05-09-2007 09:29 PM
400 small block question 400smb_s10 Engine 5 03-28-2007 12:43 PM
question on a 400 chevy small block chevy lover Hotrodding Basics 2 02-23-2006 02:15 PM
