th 400 slips in second. - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2006, 05:21 PM
I am thinking that I prolly need a trans rebuild but since I know next to nothing about trannies I thought that I would ask first in this forum.
This tranny is sitting behind a mild 454 which lives in a 31 ford model "A".
All other gears are fine car in drive shifts from first to third without visiting second If I put in second it starts in first and soft shifts into second but any real power applied to engine causes 2nd to slip badly.
First to 3rd shift is hard (when in drive)and shift rpm is based on how hard I am accelerating.
I have checked and changed fluid and filter + I changed modulator valve and checked hose.
If there is anything else that would be easy to change I will do it but If I need rebuild I will probably want to look at converting to 700r4 .
Thanks for any advice that can be offered
Larry
Old 03-14-2006, 10:24 AM
jakeshoe's Avatar
Intermediate sprag is rolled... or int clutches toasted. Needs a rebuild.
Old 03-16-2006, 08:35 PM
th400 slips
Thanks Jakeshoe, Guess its time to consider my options.
Larry
Old 03-17-2006, 05:22 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
or case lugs blown out ..... then a new case will be needed
Ok, here's the debate of the century: 383 or 400 chevy!! Cast your vote and reason killerformula Engine 303 03-28-2013 08:08 PM
400 cid SBC Shades_o_Grey Engine 20 02-04-2008 12:28 PM
chevy 400 buildup 406chevelle Engine 15 06-08-2003 03:41 PM
400 327 crank limey Engine 8 09-24-2002 07:53 AM
Small Block 400 chevyelc81 Engine 9 06-18-2002 06:10 PM
