DO NOTHING........ Until you get the rear end. Then tire size and gear ratio will tell you which ones to get........ http://www.tciauto.com/tech_info/speedo_gears.htm here is a site with all the information you need.once you have the rear end ratio and tire size.
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
www.novaresource.org/speedo.htm is another good speedo site.
You won't be able to accurately determine what speedometer hears you need until you get the rear gear ratio you want, AND the tire size you plan on using.
Both of these are the deciding factors in determining what speedometer gears you need to use to get the gear reduction necessary to give the speedometer itsself the correct input ratio. I have heard an awful lot about a speedometer input of 1000 rotations per mile, but on the other hand I have heard of a few other per mile rotation count speedometers. I have also heard (but never checked for accuracy) that there is an input value (rotations per mile) on the back of some (not sure here either) if not all speedometers. I have quite a few speedometers I salvaged from many parts vehicles I have dismantled in the past, and have to work in the shop later on today (I am on here at 1:19am) so I will try to check. |
Here's yet another nice link that explains most of the same information as the ones mentioned above, as well as the "part number" for each different gear. Hope this bit of info helps in some way.
Speedo Gear Selection |
if you are just itching to do something RIGHT NOW, buy one right in the middle.
Then, get one of the inline adapters, so you can tailor the adjustment later. If you have cruise control, get one that will fit inline just ahead of the cruise unit, so you don't have to crawl under the car, to change it. Another plus to that is being able to easily change the speedo reading, if you decide to change tire size, or axle ratio. |
| Speedo calibration | novatech | Transmission - Rearend | 2 | 02-12-2004 07:46 PM |
| speedo drive gears for muncie | 345coupe | Transmission - Rearend | 3 | 09-21-2003 07:11 PM |
| Speedo not working..4spd | Trav | Transmission - Rearend | 5 | 07-31-2003 01:21 AM |
| Speedo | DoubleVision | Transmission - Rearend | 2 | 01-25-2003 08:16 AM |
| turbo 400 failure to shift, or hold gears | 85s-10prostock | Transmission - Rearend | 3 | 11-26-2002 01:37 PM |
