TH 400 Tail shaft Bushing ID Size - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-23-2010, 06:14 PM
Drive shaft yoke OD measures 1.885
Tail Shaft ID Measures 1.894
Trans was just rebuilt.
Could this .009 clearance be the cause of my Bad Drive shaft vibration?
I'm Not an expert but shouldn't this be more like .002 clearance.
Note:
New Balanced drive shaft
Yoke has no wear marks
Old 08-24-2010, 07:38 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
that clearance of .009 will not cause a vibration
C6 tail shaft darrin Transmission - Rearend 2 07-13-2003 09:06 AM
turbo 350 tail shaft kid Transmission - Rearend 10 04-26-2003 02:36 PM
Tranny swap, What size tail shaft? Ralph Horak Transmission - Rearend 2 01-12-2003 05:35 PM
tail shaft 1badcamero Transmission - Rearend 3 12-17-2002 01:59 PM
Ford Top loader tail shaft 65 stang Transmission - Rearend 1 11-28-2002 12:10 AM
