We're winning the case!
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 09-17-2007, 08:20 AM
Houston54's Avatar
Houston54 Houston54 is offline
TH 400 Tail Shaft Change
I am looking at a TH400 with a long tail shaft for use on a project. Would like to change out the tail shaft to the short version. How difficult is this change?
Old 09-17-2007, 02:32 PM
Deuce Deuce is offline
Deuce's barnstar
Wiki editor
Last wiki edit: Wheelbase database
WHY change it ... ?
The mounting holes for the crossmember are only 1 inch or so further back.
I have installed the long 400 in a good many cars over the the years ... with no adverse effects ... I even have a long 400 Turbo in my short little 32 Ford roadster ...
IF ... you insist on changing it ... the tail housing will interchange on the case but the shaft has to be changed ...
Old 09-17-2007, 08:13 PM
Crosley's Avatar
Crosley Crosley is offline
Crosley's barnstar
Wiki editor
Last wiki edit: How to identify a Ford V8
Wiki Edits: 713
Out put shaft is last out of the case... first installed. Complete trans disassembly is needed.
At the Bonneville Salt Flats... 130mph is known as First gear ...............
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "TH 400 Tail Shaft Change"
Go Cart? mustangdude947 Engine 23 12-20-2005 10:02 AM
12.5 hp go kart airbag_89 Introduce Yourself 2 08-24-2004 10:22 PM
two sectioned tail shaft why? slavegear Transmission - Rearend 2 01-08-2004 03:56 PM
Shaft rocker trouble uhhh not good Venturat Engine 1 08-04-2003 09:24 PM
What would be required to change a 400 SBC to serpentine belt setup stonedchihuahua Engine 7 02-10-2003 05:02 AM
