th 400 trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-09-2010, 12:21 PM
th 400 trans
i have an 81 chevy elcamino i put a 400 turbo trans in it and my 350 cross member want work in it theres a special made crossmember for it but its like 250 dollars has anyone had this problem and what did you do
Old 08-09-2010, 03:08 PM
You just need the crossmember from a G-body with a 200-4R. The mount on the 200-4R is in the same place as on the TH400. You will need the aftermarket frame rail extension to accommodate this trans since the 200-4R was not offered in 1981 and your frame won't have it.
http://www.summitracing.com/parts/SUM-770307/
Old 08-09-2010, 03:23 PM
th 400
what model car had a 200-4r and will i just need to buy 1 extension for each side i really appreciate the info
Old 08-09-2010, 03:56 PM
Didn't they have that in the later Elamino/Malibu's, as well as later G-gody cars? The other G-body crossmembers should be a bolt-in as well if I'm not mistaken. So it shouldn't be hard to find one. I'm guessing mid 80's Buick/Olds/Pontiac/Chev G-body cars. Just look at the gear selector/shifter for the OD, so you don't have to bend down every time you want to check a car.
Old 08-09-2010, 04:39 PM
ericnova72's Avatar
More for Less Racer
If you want to retro-fit a dual hump crossmember to easily fit dual exhaust, the crossmember from a 64-72 Chevelle or 70-72 Monte Carlo is an easy fit, all you need to do is trim the ends and redrill some holes.
It sure beats the crappy one hump boomerang shaped factory piece.
Old 08-09-2010, 06:56 PM
SSedan64's Avatar
G-Body Trans Swap & Crossmember Info
G-Body Trans Swap>> http://www.maliburacing.com/transmission_swaps.html
Iceman / Rick has a nice lightweight ChromeMoly tube Crossmember thats cheaper. It accepts most any dual exhaust pattern with room to spare. He also has the right/passenger side Frame extension.
http://www.maliburacing.com/iceman/index.html
Installed C-member Pics here>> http://www.montecarloss.com/communit...433#Post812433
400 trans Jon G Transmission - Rearend 13 02-16-2009 10:51 AM
Who runs a truck Turbo 400 trans? upstand2 Transmission - Rearend 13 07-10-2008 09:13 AM
Turbo 400 to 700R trans Tbucit Transmission - Rearend 4 09-15-2006 12:11 PM
Chevy 350 to 400 trans combo Rockey Meo General Rodding Tech 5 09-14-2006 03:46 PM
350 trans bolt to a 400 engine. greg67 Engine 2 11-06-2003 12:27 AM
