th 400 transbrake??? or valve body - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2009, 08:15 PM
85 k5 mud truck's Avatar
****** bowtie
i was looking at a trans brake for my turbo 400 and have a couple questions
1 does a trans brake have a valvebody built in tto it or do you have to buy both????
2 if i have a transbrake do i have to have a high stall converter to leave a like 4000
3 if i have a 4200 stall converter will it leave around that or do i need a transbrake to go with it???
any help would be greatly apprecaited
Old 07-15-2009, 12:36 AM
SSedan64's Avatar
#1 The TransBrake is built into the ValveBody, purchased as 1 piece.
#2 A TransBrake will allow a high stall converter to stall at a higher rpm than Foot Braking.
#3 Yes and Depends on how hard/fast you want to take off.
Chris @ CKPerforamnce has developed a nice T-Brake. > http://www.ckperformance.com/resourc...LVEBODIES.html
The Griners are nice also. > http://www.extremeautomatics.com/pro...alvebodys.html
Old 07-15-2009, 06:44 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Some internal mods to items usually are required with trans brake install.
Hughes sells a very good - fast release trans brake
700R4 Why are the TCI manual valve body instructions so lousy? Bayley Transmission - Rearend 24 02-16-2009 12:49 PM
Valve Body Question Bobwee Transmission - Rearend 4 09-16-2007 07:21 PM
transbrake valve body problems?? eight90 Transmission - Rearend 3 09-10-2007 02:01 PM
Turbo 400 Manual valve body Tbucit Transmission - Rearend 3 05-10-2006 09:30 PM
Manuel Valve Body danarmstrong Transmission - Rearend 2 11-07-2004 08:19 AM
