Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - TH-400 "whirring noise" at med. RPM's
Old 04-13-2006, 09:06 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by NASCAR314
The noise is definatly more than "average".
Fluid and filter was changed about 1 year / 2,000 miles ago. Perhaps I screwed that up when I did it then? Not sure how I could screw it up. Pretty easy to pull pan on this car, so I may do it just for a check.
Where is the Governor located? is it inside the pan area (something to do when pan is off), or on the exterior case?
I've never heard of a governor causing a whine.... the gov is under a 4 bolt square cover near the rear tail of the tranny case
