400's governors are known for whining. If its not excessive its fine, but if it suddenly cropped up and makes more than average noise it might be wise to pull it. Its easy to do. Its held in with a little spring wire over a round cap.
sounds like the pump is working hard to pull fluid in. I'd drop the pan and change the filter if that has not been done for a while
At the Bonneville Salt Flats, first gear is known as 130 mph. |
The noise is definatly more than "average".
Fluid and filter was changed about 1 year / 2,000 miles ago. Perhaps I screwed that up when I did it then? Not sure how I could screw it up. Pretty easy to pull pan on this car, so I may do it just for a check. Where is the Governor located? is it inside the pan area (something to do when pan is off), or on the exterior case? |
I've never heard of a governor causing a whine.... the gov is under a 4 bolt square cover near the rear tail of the tranny case
Could the "pump" itshelf be going bad?
Last year, (2,000 miles ago) I replaced the pump "O-ring" and gasket, along with front and rear seals, ect.., to reduce fluid leakage. It did reduce fluid leakage. |
You may have damaged the drive lugs on the converter or the pump gear when installing it. I'm with Crossley, every t400 I heard whine had a blocked filter. Filter quality could be an issue.
Filter change fixes problem (for now!)
I changed the filter and fluid out, car runs great right now, very quite, shifts fine, ect...,
Filter Quality? is there any preferred brand, or type to use? Now I wonder how long before this filter clogs up? And WHY? Thanks for the replies, -Tom |
rip the filter open and see what is inside.
Answer to problem has been provided , tranny is repaired.. thread is closed.
| 400 cid SBC | Shades_o_Grey | Engine | 20 | 02-04-2008 12:28 PM |
| Building a SBC to rev to 8k, and have power | Andyrew | Engine | 52 | 04-17-2006 12:46 PM |
| erplexing rpms | madhat | Engine | 2 | 01-12-2003 04:53 PM |
| Small Block 400 | chevyelc81 | Engine | 9 | 06-18-2002 06:10 PM |
