th 700r trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-28-2012, 07:49 PM
th 700r trans
by mistake i let my trans run low on fuild. by the time i realize it and added fuild it would only shift out of first when i gave it alot gas. Does this mean the pump is gone. The trans was rebuild a year. Or does this the trans needs to be rebuild.
Old 01-28-2012, 10:24 PM
it could be the tv valve i had the same prob with mine it would only shift at 3500 rpms and i took the vavle body off and unstuck the vavle and it fixed it and it stuck agine and after the 3 or so times of takeing if off anf putting fresh fluid in bc the old fluid had a bunch of trash in it but i never ran mine low on fluid and i rebuildt the trans my self so that could be the prob with yours or i could be somtin els but it could be unstuck by un doing the tv cable at the carb or tbi witch ever one you are running and start the truck/car and leave it in park and snap the cable in and out fast a few times and that may fix it.hope this helps
Old 01-29-2012, 01:30 AM
SSedan64's Avatar
How low was the fluid level?
Fluid look/smell burnt?
turbo 400 or 700R trans? 454td chevy Transmission - Rearend 3 06-06-2008 06:33 PM
Turbo 400 to 700R trans Tbucit Transmission - Rearend 4 09-15-2006 11:11 AM
turbo 400 or 700R trans? Trick101k Transmission - Rearend 3 11-19-2004 12:58 PM
Chevelle Coversion to 700r using 86 camaro trans 700r theroq Transmission - Rearend 0 02-08-2004 12:03 PM
'95 LT1 w/ 700R trans Dirtbag Engine 3 04-10-2002 04:16 AM
