Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - th 700r4 lock-up
Old 06-05-2008, 05:44 PM
SSedan64's Avatar
SSedan64 SSedan64 is offline
Originally Posted by Cousin_Joe
Which pin is the A pin? I follow the 12V to A thing. As simple as possible, is it upper left? Lower left? I'm having trouble diagnosing my problem because everything I read says pin A, pin B, pin D. I have NO idea about what pin is what, I just have the stock connector on there. Thanks!
Ok, Plug should be marked with very small letters A=top left, B=top right, C=bottom right, D=bottom left.
A=12Volts feed from brake or toggle switch,........................................... ........
B=4th gear switch ground to ECM- Computer Cars, ..................................
C=3rd gear switch ground to ECM- Computer Cars, ...................................
D=Computer feed ground to activate Lockup............................................
A=Purple usually........................................... ......................................
B=Light Blue usually........................................... .................................
C=Dk Green/White usually........................................... .........................
D=Tan/Black usually........................................... ................................
Some Trans have 1, 2, 3 or 4 wires depends on model, computerzied or no Com.
