TH 700R4 tranny help - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2006, 07:19 PM
Magikal's Avatar
How can it go faster?
Last journal entry: Been a long Winter
k, my 83 K5 Blazer w/ 350 SBC has a 700R4 tranny in it and recently it is beginning to slip when in first gear (not on 1 on the column but when it actually is in low gear...it does this in all shift positions). The tranny is supposed to be a fairly new rebuild (1 year or so)..
Any thoughts or advice. Fluid is at proper level and in good shape. Bought filter and fluid today...gonna change tomorrow.
Old 04-22-2006, 09:11 PM
Is this the factory engine/trans combo? If not, what about your tv cable? Is it hooked up properly? For the best information, go to bowtie overdrives on the web.
Old 04-22-2006, 09:30 PM
Magikal's Avatar
in reply, no it is not the original combo as the blazer was originally diesel...I have had it for less than a year and it came as is...
Gonna check out the TV cable tomorrow when I change fluids. I don't know why it would be different than before...nothing has changed and the tranny worked great before.
Personally I think the band for first gear is out/going out or the pump isn't working properly to circulate the fluid.
Will post more tomorrow.
Old 04-23-2006, 07:52 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
there is NO band for first gear, it is a clutch pack.
If the TV cable is not adjusted correctly the tranny will burn up.
If the tranny slips on take off in first gear regardless of the shifter position, there is a problem in the forward clutch pack. There is an aluminum piston there, it often cracks with major pressure loss & slippage.
Old 04-23-2006, 10:51 AM
Magikal's Avatar
ok, a few things here now that I got the pan off. First the fluid does look slightly burnt but not too bad. Same for metal particles...I can see some minor glitter to the fluid and when I say minor, I mean very minor...no shavings or anything. Second, I found one of the wires going to the valve body with a bare spot (indicated by the arrow in the pic) which I believe could be a big issue...more on that later, wanted to post and then some research.
Third, the old filter was warped on the top side of it....not a good sign I would imagine.
Advice please...I need this up and running soon.
Old 04-26-2006, 05:59 PM
Magikal's Avatar
ok....I changed the fluid and filter and yes it helped. But there still seems to be some slipping...seems to be more in the high 1st/low 2nd range...I did do a wire up for the Torque Converter lock-up using a 3-way toggle. It is supposed to option for (1) 4th gear lock up only, (2) off (no lockup in any gear), or (3) 2nd,3rd,& 4th lock up
I did run an LED inline to indicate when the lock up is occuring. The 4th only lock up setting is working great as is the off setting. But the 2/3/4 setting isn't working. Can someone tell me what the switch indicated in the following picture does exactly? I can't find it anywhere.
Old 04-26-2006, 07:30 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
where did you get this wire up information?
The pressure switch you are concerned with is not the correct type for what you are trying to do.... IF I am looking at the position of the wires correctly. It is difficult to follow the path of each wire in the photo.
The second switch does not 'lockout' the converter. Incorrect term, it is a lock up converter . That switch is correct for what you are trying to do.
The first switch needs to be a black metal switch which is a normally closed switch.
Oh , the switch you want info on is plugged into the 4-3 sequence valve assembly
Old 04-26-2006, 08:10 PM
Magikal's Avatar
this was the original wiring setup/schematic....The pics you see are what I had when I dropped the pan.
All the data I collected is via the knowledge base here on Hotrodders.com
This is the one of many links that I followed.
http://purplesagetradingpost.com/sum...o/700R4p1.html
As I understand it, the solenoid locks up the converter and the switches are different ways of activating the solenoid. I know the one switch is for 4 gear lockup, actuated when pressure reaches a certain point AND it is in 4th gear.
now, what activates the other switch in question?
Old 04-26-2006, 08:30 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Sumner ( Purplesage Trading Post) is a good friend of mine.
You need to re-read his wire / toggle switch diagrams. You do not have your wires setup as his is.
His setup uses one pressure switch , not two on the v-body. The switch you are worried about is unneeded, not used , can be removed and plug the hole.
Old 04-26-2006, 09:27 PM
Magikal's Avatar
this is how the wires WERE...they no longer are wired as such...I did run through the second switch thinking it should be....so basically you just supply power to the solenoid direct to activate the torque converter locker full time on one leg of the switch...the other routing through the 4th gear pressure switch.
All the same, what system is that second switch on?
700r4 tranny in 2nd gen 1980 camaro !HELP! william27103 Transmission - Rearend 10 11-02-2005 06:53 AM
different types of 700r4 tranny 49dream Transmission - Rearend 1 05-02-2005 08:49 PM
TH-350 - 700R4 tranny swap 73monte Transmission - Rearend 3 03-25-2004 01:26 AM
700r4 tranny swap chevcamz28newbie Transmission - Rearend 6 08-06-2003 01:52 PM
Repalcing rear seal in 700r4 tranny Jag Daddy Transmission - Rearend 7 07-05-2003 11:44 AM
