TH200 TV adjustment help - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-11-2006, 07:18 PM
I'm trying to adjust the TV (throttle valve) cable on a TH200 transmission at the WOT position. But when I pull the TV cable out, it seems to travel easy then the last 5/8" it pulls some what hard. Is this typical? Do I pull the that last 5/8"?
Old 09-12-2006, 07:02 AM
tnsmith10's Avatar
when will it rain???
at WOT the t.v. cable needs to be completely tight
