TH200 vent - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-02-2006, 04:04 PM
TH200 vent
Where is the vent located on the THM 200? I just had a second rear seal leak. The seal was replaced not long ago, so I want to make sure it's not building up pressure before this new seal leaks.
Thanks,
-Michael
Old 04-02-2006, 07:38 PM
Depends on the model T200. Some are in extension housing/tail section, some are at top of case behind the pump area.
Old 04-02-2006, 10:01 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
If the rear case seal for the drive shaft yoke is leaking 'again"...... did you replace the bushing in the tail of the case when the seal was replaced?
Old 04-03-2006, 08:13 AM
I didn't even think of the bushing. The first time I had all the seals done at a trans shop, I was in a hurry and needed to use the car. That was about a year ago, no more than 10k miles.
This time when I pulled the drive shaft off, I did notice play in the trans output shaft. There was maybe 1/8" movement in all directions. How difficult is it to replace that rear bushing (can it be done on the car)?
BTW, this is a THM 200C trans.
Old 04-03-2006, 07:07 PM
The output shaft of the T200 WILL move a bunch when there is no yoke in the trans. The rear bushing supports the yoke along with the output shaft.
Crosley wants you to check for bushing wear in the area the yoke contacts the bushing. The yoke must be smooth and not worn down on the diameter.
A trans shop can replace the bushing (in the car) IF they still have the extractor and installation tools
Old 04-03-2006, 07:53 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
as Chazmac points out the output shaft will move around with no yoke in there. normal for a t-200.
An extractor tool is needed to change out the bushing since the t-200 does not have a removable tail housing.
Most of us old fart tranny guys have at least one GM bushing extractor tool around.
Old 04-04-2006, 03:02 PM
Okay, I understand now. I checked on the yolk now that it's back in the trans, there's no play. There was no noticable wear on the yolk except where the old seal had been. I gave it a light polish with 4-0 steel wool before reinstalling it.
The new seal is a bit different than the old spring loaded seal I pulled out. It looks like it is sealing on a new section of the yolk, so I hope this one stays leak free!
Motorized cowel vent? genr8rs Body - Exterior 1 03-23-2006 09:25 PM
55 2nd series cowl vent gator412 Body - Exterior 3 02-28-2006 05:47 PM
Rearend Vent Cap spanky36 Transmission - Rearend 3 01-30-2006 08:47 AM
Vent controls DoubleVision Interior 0 09-18-2004 06:17 PM
'64 Nova Cowl Vent 41chev Body - Exterior 2 03-21-2004 06:52 AM
