TH200C to Powerglide swap? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2011, 07:45 AM
JLBpontiac350's Avatar
85' grand prix,th200M,chev305
any ever changed out a th200c 3speed auto for a Powerglide? how easy is it, i know a Powerglide will swap right out for a th350 with no mods to the crossmember or driveshaft. and a TH350 with a 6" tail will be a direct swap without any mods for the th200c. any thoughts?
JLB
Old 04-30-2011, 12:32 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
You'll need to change the slip yoke.
Rich
Old 04-30-2011, 07:04 AM
Overdriv's Avatar
I'd go with a 350C, goes right in with minimal changes.
Old 04-30-2011, 07:44 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
JLB
you are mostly correct on the power glide. Early aluminum glides were shorter and had a course spline on the out put shaft.
Bolt in a fresh t-350 trans in place of the t-200 trans and be done with it. This was a common swap back in the 1980s when a t-200 trans failed at low miles.
Edit: On other item on the glide is the linkage. Glides usuallly did NOT have a bolt on shifter linkage arm.
The TV linkage on the glide would need to be dealt with too as it works backwards to the typical more modern trans. Glide linkage for TV is pushed , not pulled
TH350 to powerglide swap kficiur Transmission - Rearend 2 10-16-2009 06:56 PM
Powerglide swap to 350 Turbo cixty6 Transmission - Rearend 6 06-11-2008 09:35 PM
Powerglide/ Turbo 350 swap sicksixseven Transmission - Rearend 10 09-26-2006 07:00 AM
Powerglide/TH400 Swap 67ssguy Transmission - Rearend 3 03-15-2005 08:03 AM
235 Engine / Powerglide to 3 speed swap New2theart Engine 2 07-16-2002 07:22 PM
