th350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2011, 09:20 AM
th350
What's up guys. I have a th350 transmission that has been rebuild with a B&M shift kit. I have the transmission behind a small block 350 that has been worked. My transmission has begin to slip an I'm out of suggestions on how to fix it. I have check the atf and I have also replaced the vacuum modulator but it still wants to slip. Does anybody have any suggestions on how to fix this problem?
Old 05-17-2011, 04:18 PM
B.A.M.F
yep yep with a new transmission or a freshly rebuilt one you are suppose to change the fluid and filter after the first 500 miles, ask me how i know lol, if you have just driven it normal you may be able to prevent a head ache, change the fluid and the filter cut the filter open and look for any debris that would indicate internal damage, also take notice of any smells of burnt fluid, i know tranny fluid stinks to begin with but if it comes out a brownish or black color then you "toasted" the transmission, if not a simple fluid change and filter should rectify your problems , hope that helps
Old 05-17-2011, 05:17 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
Welcome to Hotrodders.com Glad to have you with us.
If it's slipping the fluid will be burnt. If It was my car I'd pull the trans now, before it get's worse & leaves you sitting somewhere.
Rich
Old 05-25-2011, 08:37 PM
Thanks guys for the help and I plan to pull the transmission out the weekend and try to diagnose the problem. If its too much to fix or too much of a hassel I'll probably save up to purchase another one. Another question. What gear set up should I use for my rearend?
What will a TH350 Handle? Many Th350 Quetions, Shift kits? Warrant Transmission - Rearend 2 12-18-2005 09:46 PM
old th350 swap for new th350 72donk Transmission - Rearend 2 08-31-2005 09:49 AM
TH350 to M21 or TH350 to 700R4 thecamaroguy Transmission - Rearend 6 02-10-2005 01:18 PM
help, TH350-C Vryice Transmission - Rearend 4 05-12-2003 01:38 PM
picked up TH350, PG -> TH350 darom Transmission - Rearend 4 03-16-2003 09:06 AM
