Th350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2003, 10:55 AM
madhat's Avatar
Th350
I have an 85 Regal Limited which i will soon be converting to a turbo regal. It has the 3.8 with a TH350...how much torque will a stock tranny handle? Whats the stock torque converter's stall speed? (the guy before me had the 350 rebuilt (stock) only like 500 miles ago. Also, what is the bestplace for a transcooler? infront of the radiator? also, those trans oil pans that have the air cool vents on the bottom, do they work?
thanks for your future help.
madhat
Old 07-31-2003, 01:51 PM
gt2betubbed's Avatar
Kid With A Wrench...
Last journal entry: The Blower and test fit.
I would say that a stock 350 could handle around 300 lbs of torque. I believe the stock converter's stall is 1100-1500, but I'm not sure, and I like to mount tranny coolers along the frame since I'm allways worried about overheating. If you plan on making more torque than that, I would just run it with the tranny as is, and wait till it blows to fix it, but that's just me...
Good luck!
Old 07-31-2003, 02:36 PM
madhat's Avatar
Hey thanks GT2, that's what my friend said to do, he's keeping the stock 350 on an 80 El Camino too(360hp and 360torque). And yeah...my rear wheel power is going to be in the range of 300-330hp and 400 torque.
Old 07-31-2003, 06:43 PM
Crosley's Avatar
Wiki Edits: 1659
Cool
If that T-350 is the original tranny to the car it will be a lock up converter type tranny which is a T-350C.
Since it is a 3.8 V6 engine in the car the tranny may be a T-250, not a T-350C.
A quick look near the cooler line connections on the passenger side of the tranny case for a threaded stud protruding from the case with a nut on it.
