TH350 3rd gear slipping?
Hi all! I'm John and I'm new to the forum. My hotrodding days are few and far between these days due to spending most of my time with an '83 CJ7, but I still do what I can to eek out whatever performance it'll give me. I have swapped a GM SB into it with Holley EFI and a TH350. The TH350 is where I'm having the problem and I've noticed that you all seem to have some very knowledgeable people on this forum, and I'm losing my mind trying to figure this one out, so I thought I'd ask.
I just recently had this tranny rebuilt. After I put it in, things seemed to be working fine. When the tranny is cold, it shifts perfectly - I've adjusted the modulator to set the shift firmness where I like it. However, once the tranny warms up, 1 to 2 always shifts fine, then 2 to 3 shifts fine but will only seem to stay in 3 for a short while. After that it seems to slip. If I pour the RPMs to it, it will still pull a little, but I can also shift it down to 2 both manually and through the kickdown and it works normally. Reverse works fine. I do notice that 1 is tighter than normal, but, other than that, it works fine. Someone told me this could be the governor, but I'm just not convinced. Do any of you have any thoughts on this? I realize that my post doesn't fit in here just right, and I apologize for that, but I really do appreciate any help you might be able to offer. |
Hi John:
Without seeing the trans it is a little hard to tell but it sounds like you have an internal problem that will call for removal, but first check your TV cable setting. Unlock the retainer and then go wide oprn throttle and relock retainer and see if that helps. You can check the govenor by pulling it out of the case and hold it by the gear to allow butterfly weights to open then with the other hand close and open the butterflies watching the valve inside the govenor to see if it moves up and down with the opening and closing of the weights. Other than that you may need to check v/body, and check balls and then internally. Jack |
| TH350 and what happened to 2 gear? | Fryksten | Transmission - Rearend | 5 | 02-25-2004 07:46 AM |
| tranny slipping 3rd gear..... | 73monte | Transmission - Rearend | 1 | 12-20-2003 02:22 PM |
| th350 no 2nd gear | mkolstad | Transmission - Rearend | 2 | 07-10-2003 08:56 AM |
| th350, no third gear | ummduh | Transmission - Rearend | 2 | 04-03-2003 03:44 PM |
| New TH350 Starts out in 3rd gear? | roygrimm | Transmission - Rearend | 2 | 01-22-2002 07:37 PM |
