th350 6 inch to 9 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2007, 04:15 PM
th350 6 inch to 9
while at the local reycler I came across a th350 with a 6 inch tailshaft at a good price. Now can I slide the innards of this one into the now defunct case of my 9inch 350 and is this something I should attempt to do on the tailgate as I haven't been endowed with a garage or even a piece of concrete for that matter.
Old 03-17-2007, 10:04 PM
fast68's Avatar
likes chevy trucks & boobies
you could, if you have compressor tools and such that you will need
same parts and case otherwise, as long as one isnt a C model
if the input shafts are identical in every way then it will work
if not then you wont be able to no way no how
good luck
Old 03-28-2007, 05:38 PM
cases are identical do you just swap tail-shafts or do I have to swap the entire case? any help would be appreciated .
Old 03-28-2007, 06:08 PM
Last journal entry: car is painted
If you haven't worked on a transmission before, don't touch it. It is not as simple as take a few bolts out and slide out and slide in. Clearances need to be checked and you need some special tools. Try to take apart your junk trans and you will see.
th350 with 9 inch ford rear? harvey wells Transmission - Rearend 2 05-12-2006 06:17 AM
th350 in 67 Tempest csob Transmission - Rearend 1 02-19-2006 10:45 AM
T-350 to 700r4 swap? trumick Transmission - Rearend 6 09-23-2005 09:19 PM
low profile tires for 15 inch Halibrand reps peranaman Suspension - Brakes - Steering 3 06-28-2005 05:36 AM
