TH350-700R4 mounting - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-02-2003, 09:43 AM
stea's Avatar
Post TH350-700R4 mounting
Need to know the mounting distance from the rear of the engine. Is the 700 the same as a 350? At this point Im not sure which tranny I will use but I need to prep the frame and have it all set up before i take it to the powder coaters. THANKS
Old 04-02-2003, 01:06 PM
Post
I just took some measurements. From trans mount holes centerline to engine mounting surface is 20 3/4 inches for the th350 and 22 3/8 inches for the 700.
Old 04-02-2003, 01:20 PM
stea's Avatar
Post
Thanks Jason, guess I need to make a discision on which to use.
