th350 with 9 inch ford rear? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2006, 07:05 PM
I am preparing to install a chevy v8 with th350 into my car which has a ford 9 inch posi set up. This being a new procedure for me,
I was hoping someone might be able to give some advice about what driveshaft componets to use with this combination. Any help greatly appreciated.
Old 05-11-2006, 11:31 PM
Chopt 48's Avatar
There are several variables to contend with.
Chevy uses a couple of different style jonts depending on the year. The big difference is outside locks or the inside locks/c-clip to replace the oem plastic. Either will work ok but for conversion work I prefer the outside locks.
The ford rear could take one of several joints depending upon original application. You have to do a bit of measuring and decide what you need.
You may have to have a custom shaft built or poke around in a few driveshaft piles to see if you can find one the right size.
One possibility, they do make cross over joints that match sizes and designs. They work good but can be a bit hard to find and spendy to buy,
Here is the Summit U joint page. You can play on there a bit and do some figuring on what it will take to make it fit. http://store.summitracing.com/egnsea...4&autoview=sku
Old 05-12-2006, 05:17 AM
th 350 with 9"ford
As was previously stated there are several different yokes on the 9" ford,depending on year and application. I can speak from my personal experience,I put a narrowed 9" rear from a ford van under my S-10 and didnt have to change the U joint,the chevy joint bolted right up with no problem. Last winter I replaced the 10 bolt camaro rear under my 39 chev with a 9" bronco rear end and again I didnt have to change anything,the u joint bolted right up to the bronco yoke.
47 ford rear swap (parallel leaf springs) ONEGALONLY Suspension - Brakes - Steering 4 10-06-2005 07:06 AM
Ford 9 inch rear end... whinning noise??? bg Transmission - Rearend 5 09-28-2005 01:03 PM
ford rear end jay1 Introduce Yourself 1 09-18-2004 03:29 AM
rear differential for 46 ford rp1 Suspension - Brakes - Steering 1 09-08-2003 07:43 AM
Ford 8" Rear mustang66maniac Transmission - Rearend 2 02-22-2002 02:14 PM
