TH350 - adjust shift point? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-18-2006, 03:07 PM
sabino56's Avatar
I understand there is an adjustment screw inside the where the vacuum line plugs into the transmission. I just put a new engine and a TH350 into our 65 Belair - it shifts too soon. Which way do you turn the screw to make it shift later? I'd like to turn it in right direction on first try to minimize the number of times I have to jack the car up and get underneath!
Thanks
Ed
Old 11-18-2006, 06:01 PM
airworld2's Avatar
shift
in for later shifts, out to shift later.
airworld2
Old 11-18-2006, 07:01 PM
jray's Avatar
HuH??
Old 11-18-2006, 08:28 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I believe airworld2 meant to post:
Thread the modulator screw in for later light throttle shifts..... out for earlier light throttle shifts
Old 11-19-2006, 09:14 AM
airworld2's Avatar
my answer was to the point, he ask which way to adjust the screw. my finger's need the rest. (too much typing) lol
airworld2
Old 11-19-2006, 11:06 AM
sabino56's Avatar
Thanks for response. But now you have me curious with the addition of the "light" shift comment.! As far as I understood, the crispness of the shifts can be changed with kits that mess with the control valves and/or clutches/bands or whatever inside - but there wasn't anything which you can do on making the shifts harder from outside the transmmission. Is this correct?
Old 11-19-2006, 06:16 PM
airworld2's Avatar
modulator on 350 deals with engine load via vacuum source, which can determine shift timing along governor. sometimes adjusting to later shift will firm them up but this is not a cure for slipping or a shift kit. to firm up shifts you need to enlarge feed holes and increase line pressure's.
airworld2
th350 1st gear manual shift problem desman Transmission - Rearend 6 02-08-2004 03:15 PM
TH350 WOT shifting eball Transmission - Rearend 1 09-05-2003 10:09 PM
Changed clutches mid 70's TH350 Early1 Transmission - Rearend 2 05-11-2003 08:10 AM
TH350 shift kit mustang66maniac Transmission - Rearend 1 11-15-2002 11:19 AM
TH400 shift point...help Ted655 Transmission - Rearend 1 10-14-2002 11:18 AM
