th350 air check the forward drum problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-17-2011, 09:48 AM
bodie filyaw's Avatar
GMC TRUCKS
when i air check the forward drum like the book says the air comes out of the hole by the shaft inside the drum. if i cover that hole with my finger it air checks. please tell me what i done wrong
Old 02-17-2011, 11:28 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Are you air checking the forward assembly w/it placed onto the pump?
Old 02-17-2011, 11:29 AM
GMC TRUCKS
yes i have it like the book says.
Old 02-17-2011, 01:21 PM
foward clutch
pump seal rings on right?
Old 02-17-2011, 03:39 PM
GMC TRUCKS
they were,but for some reason i had to go back with the steal rings and it air checked fine
4l80E Direct and Forward drum piston interchange blade42003 Transmission - Rearend 4 01-05-2011 09:25 PM
no forward but has reverse in th350 84 k10 Transmission - Rearend 1 12-01-2010 07:32 PM
Torrington Bearing between Direct and forward drum? 6426yy Transmission - Rearend 2 05-05-2008 02:28 PM
th350 no forward gears yardbird Transmission - Rearend 7 06-26-2007 01:13 AM
90/91 - 93 AOD Forward Clutch Drum ? macx Transmission - Rearend 0 05-18-2005 08:03 PM
