TH350 all the fluid came out - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2011, 05:52 AM
alexcamaro307's Avatar
Help please!!!
yesterday i was driving the car, the transmission was in D, i pressed the gas pedal hard passing the 4000 rpm and few second later a lot of smoke started to came out of the bottom of car, i stopped and saw the red fluid burning in the exhaust pipes.
I saw all the transmission fluid coming out from the oil pan and the gasket, did the gasket burn??? i lifted the car and saw that the only fluid leak was coming out the gasket and the pan...i wonder what happened? never happened before. The last time the gasket was replaced was about 4 years ago...any idea?
help...
Old 03-31-2011, 07:05 AM
sqzbox's Avatar
My pipes are my music
Sounds like you need to replace the pan gasket. If it were a pressure problem from over heating, there's a lot of other places the fluid would have come out before the pan gasket. Check the bolts and see how tight they are. Might just have been the fact that they weren't re-tightened after installation or the gasket shrunk over the last few years and the sealer (if used) just couldn't hold the fluid back any longer. Your darn lucky the car didn't catch fire and burn to the ground which happened to the local cops car last year where I live. The Crown Vic was a total loss.
Old 03-31-2011, 07:27 AM
BOBCRMAN@aol.com's Avatar
Sounds like the vent on top of the trans is plugged.
Old 03-31-2011, 07:48 AM
How can i see the vent on the top? do you mean by "plugged" that the vent on top is dirty?
purging fluid from my th350 strangebrewgarage Transmission - Rearend 1 03-27-2011 09:18 PM
th350 check fluid Vincentnova Transmission - Rearend 1 09-23-2010 03:34 PM
How much fluid in a TH350 to start? lngliv3 Transmission - Rearend 2 05-22-2010 04:51 PM
Th350 dirty fluid should i buy it? filthy one Transmission - Rearend 1 03-24-2010 01:06 AM
TH350 Fluid Level 47willys Transmission - Rearend 6 11-03-2003 06:18 PM
