TH350 Anti-Clunk/Case-Saver Failed? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2011, 08:34 AM
XNTRCI-T's Avatar
AKA Lee in KC
I have a TH350 behind a 6-71-huffed SBC (500 hp +/-) in a 1900# T-bucket. The tranny is a TCI Super StreetFighter that has been rebuilt by a local race tranny builder after the supposedly-hardened intermediate sprag race failed after 1000 miles (another story ). The tranny has about 2000 miles since local rebuild. This car is not raced, but I do get on it pretty good from time to time.
Within the last several hundred miles the tranny has begun "clanking" when dropping into first (either by hand shifting or auto down-shifting when coming to a stop). Using a stethoscope I've been able to isolate the clank to the center-support area of the tranny case. From what little I know about the guts of a 350, I suspect the anti-clunk spring, if there is one, has broken or dislodged, or if there is a case-saver, it isn't doing its job for whatever reason. The guy who rebuilt my tranny has moved out of the area, and I can't get his input.
My question is this... I'm leaving tomorrow for a week-long cruise where I will be putting maybe 1000 miles on the T. What is the worst that can happen?
Old 07-10-2011, 11:26 AM
XNTRCI-T's Avatar
AKA Lee in KC
Video Added
I jacked up the rear end and hand-rotated the driveshaft with the tranny in NEUTRAL. Video shows amount of movement and sound. Is this normal?
YouTube
Old 07-11-2011, 02:19 PM
XNTRCI-T's Avatar
AKA Lee in KC
If you do not want to register, fill this field only and the name will be used as user name for your post.
Anti clunk spring BJV269SS Transmission - Rearend 12 02-05-2008 04:06 AM
79 TA, clunk, clunk, clunk sounds under hard steering Gladis Suspension - Brakes - Steering 13 05-01-2007 07:34 AM
Did I install my Anti clunk spring and Overrun Band right? (T-350) Warrant Transmission - Rearend 7 06-06-2006 06:42 PM
Anti-clunk spring? Marcus Transmission - Rearend 2 11-01-2004 12:09 AM
case saver maiors2 Transmission - Rearend 1 05-02-2004 11:13 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
