th350 burnt cluthes - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-08-2010, 07:29 PM
th350 burnt cluthes
So I took th350 trans apart. Forward clutch pack is burnt smack up and the intermediate pack is starting to burn. Talked to hughes tech guy. He said to put a reman pump and new set of clutches in it. Is there a place that I can just buy the clutches for trans and not the whole pump? And a front pump? Are the red clutches the best or do they make better ones?
thanks
Old 12-09-2010, 02:20 AM
SSedan64's Avatar
The Alto Red Eagles should be good. There're others, Raybestos Red Stage 1's, Blue Plate Specials are probably best but may be overkill & are pricier.
A Remanned Pump is fairly cheap. If yours has wear in the Body/Cover it will require machine work. The clearances are critical for proper operation.
Inspect everything before you buy or order parts.
Parts:
http://www.makcotransmissionparts.com/350-350C.html
http://www.transmissionpartsusa.com/...arts_s/598.htm
Rebuild Info:
http://www.hotrodders.com/forum/th35...ch-145361.html
http://th350.netfirms.com/browser.htm
Old 12-09-2010, 05:24 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Buy OEM quality and you will be fine.
Borg Warner , Allomatic, Raybestos are all good brands, they should be a lower price than the fancy red or blue or other color materials.
Also , kolene steel plates are un-needed
Old 12-09-2010, 06:01 AM
air check the clutch pack to be sure there isn't eccessive clearance.
Old 12-09-2010, 05:18 PM
Thanks for the replys. Appreciate the info
T-350 or T-400 in C10 ekacpuc Transmission - Rearend 2 05-17-2010 02:17 PM
T-350 Rebuild Tech jakeshoe Transmission - Rearend 10 10-05-2008 03:58 PM
Transmission swap: TH250 to TH350 Torque converter issues. 35oldstruck Transmission - Rearend 5 05-21-2008 03:43 PM
Stock TH350 capacity 307malibu Transmission - Rearend 7 11-01-2007 10:16 AM
TH350 wont do anything - a few questions justchris Transmission - Rearend 2 02-15-2006 11:56 AM
