th350 bushings - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2009, 09:28 PM
keesey1985's Avatar
th350 bushings
how do you remove the output shaft bushing??
i am stuck and want to keep moveing forward
any help will be better than were i am now!
Old 05-18-2009, 10:14 PM
keesey1985's Avatar
got it
cut it with a chisel
Old 05-19-2009, 09:31 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
In the future, you can get under the edge of the bushing w/an awl, then lift an edge enough to grip it w/a needle nose.
If it's a split-type bushing, do this at the split.
Then, twist the end towards the center and the bushing will roll up enough to easily be removed.
Be careful no matter how you do it that you don't damage the surface where it seats.
T-350 Rebuild Tech jakeshoe Transmission - Rearend 10 10-05-2008 03:58 PM
Transmission swap: TH250 to TH350 Torque converter issues. 35oldstruck Transmission - Rearend 5 05-21-2008 03:43 PM
Redoing 74 Nova Bushings - Initial Planning topdogger Suspension - Brakes - Steering 8 11-13-2006 10:28 AM
Mustang-II rack & pinion mounting bushings?? NASCAR314 Suspension - Brakes - Steering 4 02-08-2005 12:53 PM
Urethane Bushings - Yes or No?? Jim Weeks Suspension - Brakes - Steering 5 05-01-2002 08:12 AM
