Th350 can't manually engage 1st gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-30-2011, 03:53 PM
Hi I have a 79 Camaro 305 with a th350 and I changed the intake manifold and carb to a Stock 4bbl of a el camaino and now I can't drop it into 1st from second but second from 3rd seems ok .... there is also a metallic sliding and click sound when I slow down I think even if I'm still in 1st it happens about10 - 15 k"s any ideas would be helpful.
Old 11-08-2011, 06:49 PM
Dogbreath077's Avatar
Old School Motorhead
Slide and click
It sounds like you have a linkage interference problem. Check your installation of the kick-down lever, and make sure it is not interfering with the shifter linkage. I've seen a bunch of shifting problems occur after "simple mods". Please repost with results.
Old 11-08-2011, 07:22 PM
Hey thanks for the reply .. I haven't hooked up the kickdown cable because it is to long for the bracket and link on the carb I'll try and recktfy this and SE if it changes!!
727 will not change manually into 1st gear harley7985 Transmission - Rearend 7 07-21-2011 10:53 PM
fresh th350 will not engage at all... pump? psbaker75 Transmission - Rearend 1 03-15-2011 03:36 PM
trans has no 3/4 gear,only shift when shifted manually. firebird trans Transmission - Rearend 1 09-25-2010 06:55 AM
TH350 kickdown won't engage Bill-E-BoB Transmission - Rearend 5 04-02-2010 01:14 PM
my th350 popped out of reverse and will not engage strokedout Transmission - Rearend 4 09-07-2009 11:39 AM
