I have welded up many of these successfully. Just be sure that you don't make the same mistakes the previous owner did. There must be some "give" in the three point mounting or the housing will break again.
Sure it can be welded and will hold up, just make sure you bolt it up to a dummy block so it aligns properly. The 700R4 in my 34 had a mounting ear broken off. I bolted it up to a bare block and a friend of mine Heli arc'd it...good as new.
Vince |
Thanks for the info guys. Appreciate the tip Vince, I was asking myself how I was going to get it back in alignment since it`s cracked almost all the way around the bolt hole at the 2 o`clock position and it`s got a short straight crack down by the dowel pin. I checked the dowel pins on the block it was bolted to, they were okay. Many don`t know pushed in dowel pins or lack of them will cause the case to crack as well so it was the first thing I checked.
It had stock motor mounts, however, the trans mount was broken completely, when my nephew removed the engine, he was hoisting it up and heard a loud clunk, he found the trans just fell out. The truck was a 77 chevy flat bed with a 8 lug floating rear. someone had transplanted a roller cammed 305 in it. We bought the truck for $400. I wanted the trans, my nephew wanted the rear. We sold the engine for $400 and made our money back. After the truck is stripped for the rest of the parts wanted off it the rest goes to the scrap yard. The engine ran sweet, I wished I could have kept it, as it would have been perfect for a future cutlass I plan to build. I guess I`ll have to dig up another one later on. Thanks again for the tips guys. |
A poor substitute for using an engine block to hold alignment as you weld, is to bolt the tranny case up to an engine stand that has been already set to fit a block. You need to use bolts and nuts and wrench them down tight before welding. Obviously, if a bolt hole is involved, having one of the stand's "arms" holding at that point will work better.
Nowhere near as good as a block- but better than nothing. I'm sure you have a block you can use, but possibly this will help someone else. |
| th350 case problem | tomthecomic | Transmission - Rearend | 1 | 01-17-2008 11:07 AM |
| broken th350 case Why? | tomthecomic | Transmission - Rearend | 5 | 11-03-2007 07:37 PM |
| TH350 wont do anything - a few questions | justchris | Transmission - Rearend | 2 | 02-15-2006 11:56 AM |
| th350 to 700r4 swap?????????? | trumick | Transmission - Rearend | 6 | 09-23-2005 08:19 PM |
| TH350 to M21 or TH350 to 700R4 | thecamaroguy | Transmission - Rearend | 6 | 02-10-2005 01:18 PM |
