th350 case problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2008, 08:15 PM
th350 case problem
I keep stripping treads in case at the pump. I have helicoild 4 and it works. My problem is one of the holes has cracked off. I think I will be able to get a bolt in to seal the hole. If you are looking at the case facing the pan it is the one in the 7 o'clock position. Their are three next to each other it is the far right. It does not have any holes going to the pump. It cracker half or the top half that face the clutches. Will I have a problem. I am only using 18lb.
Old 01-17-2008, 11:07 AM
Those bolts torque about (180 in. lbs) 15 Ft.Lbs, you need an inch pound torque wrench, that may be your problem.
Try putting a heli-coil in it, or put like a plastic straw in the hole and epoxy it up and install a heli-coil.
Vague th350 problem topdogger Transmission - Rearend 10 04-23-2007 03:49 PM
TH350 problem catfishtn Transmission - Rearend 4 03-31-2007 08:12 AM
TH350 Manual Low Problem HELP! andrewhotrod Transmission - Rearend 3 01-25-2004 10:25 AM
th350 speedometer problem john69 Transmission - Rearend 4 06-17-2003 06:38 PM
th350 problem..... oldcarguy85 Transmission - Rearend 2 04-24-2002 04:06 PM
