th350 convertor - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-13-2003, 04:38 PM
jum jum is offline
th350 convertor
If you dont put enough tranny fluid in convertor when installing , will it regulate itself on startup. How does the fluid get in convertor when car is running? Thanks, Jum
Old 12-13-2003, 04:41 PM
poncho62's Avatar
Wiki Edits: 5
The fluid gets into the converter through the splined collar in the middle. If there isn't enough in it, it will flow in there. Just get as much in it as you can.
Ontario Rodders
Old 12-13-2003, 07:13 PM
Rubberman2003's Avatar
/\ What he said
Someone told me to put like 2 qtrs. Im not sure if thats right or not. I cannot remember how much i put in my Th350 convertor.
Old 12-13-2003, 08:06 PM
Crosley's Avatar
Wiki Edits: 1659
Cool
All the converter needs is a splash of fluid.
The pump constantly refills the converter since this fluid travels from the converter to the cooler and returns to lube the tranny.
