th350 convertor queston... - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2011, 06:04 PM
How can I tell if me converters going out? The converter is an th350, 2500 stall. The problemim having is, at a low rpm, the transmission pulls off and shifts out fine. But accelerate at a high rpm I feel a vibration wen it slips. What's my problem? Side the transmission need to be rebuilt?
Old 06-19-2011, 07:21 AM
delawarebill's Avatar
slippp'n away
i'm not an expert on this.. but if your giving it good throttle and reach some rpm higher then 2500 and it shacking.. i'd be looking hard at the converter.. from idle to 2500 u'll get some slip but after that it should be locked up... i've got the same setup on my bucket and never had a problem.. now don't forget the wt of the veh has alot to do with it... if your car/truck wt's alot u really don't need a high stall, but a bucket is different..
Old 06-19-2011, 08:29 AM
It will slip/vibrate well under 2500 just normal driving. Say for example, pulling on to an intersection. Where it takes a good bit of acceleration. Around 2000 or less it pulls...but after it hit 1-2nd, 2-3 it slips/vibrates also. I still can feel the shift kit
th350 convertor I D 71corvette Transmission - Rearend 1 05-01-2011 03:18 PM
intake queston bandit327 Engine 23 04-22-2010 04:12 PM
another STUPID 305 queston kwopper07 Engine 13 09-20-2007 10:36 AM
th350 torque convertor installation MickiG13 Transmission - Rearend 2 11-07-2004 12:21 PM
th350 convertor jum Transmission - Rearend 3 12-13-2003 08:06 PM
