the pressure you post for cooler system is common. The trans gets hot? How hot? Where do you measure the temps?
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Ok, thanks.
I do off road racing. Prolonged use will see the temp rise to 250 deg f. The temp probe is in the sump. It also blows oil out of the breather when hot, which understand can be symptomatic of a worn oil pump. However if the pressure is about right then I guess this is unlikely. |
| Oil Pressure Line? | rhinz1966 | Engine | 1 | 11-09-2009 06:00 PM |
| 3L80HD cooling line pressure | fast68 | Transmission - Rearend | 6 | 04-02-2009 07:56 PM |
| 700r4 line pressure check...Crosley..anybody | uncleaud | Transmission - Rearend | 1 | 02-24-2009 08:01 AM |
| vaccum line for th350? | fireforsin | Engine | 3 | 05-25-2006 06:13 PM |
| Another cooler line question | MINITRUCKIN2000 | Transmission - Rearend | 3 | 03-26-2006 03:09 PM |
