th350 detent cable - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-01-2011, 06:15 PM
th350 detent cable
I have a TH350 in a 75 corvette. The car had the lackluster L48 motor when I bought with some minor mods. The car had not detent cable when I bought it. When in drive, the car would shift into passing gear pretty consistently.
I have since stroked the motor and some other upgrades. Since I put the engine back in, the tranny will not downshift to passing gear. I did install a 2500 stall. That is the only difference than before.
It also shifts into 2nd and 3rd pretty quickly. It doesn't let the engine get into the power band enough.
I have read several posts on here that say you won't get downshifts if you don't have the detent cable, but I didn't have it before and it would downshift to some degree.
Any help is appreciated. I know zero about transmissions!
Old 05-01-2011, 06:17 PM
Crosley's Avatar
Wiki Edits: 1659
in some situations the vacuum modulator will make the trans down shift if the detent cable is un hooked.
Sounds like you need a detent cable now or manual shift the trans at the RPM desired
Old 05-03-2011, 08:31 AM
SSedan64's Avatar
If your Stroker engine has a Cam with longer Duration, it probably has less/lower vacuum signal going to the Trans Modulator.
Th350 detent cable pedigo78 Transmission - Rearend 2 04-08-2011 06:57 AM
Help with detent cable V305 Transmission - Rearend 1 04-09-2009 09:33 PM
detent cable? sexypizzaman Transmission - Rearend 18 12-18-2008 08:11 AM
? about the detent cable on a TH350 streetmaster42 Transmission - Rearend 5 08-19-2007 07:10 AM
Detent Cable? HammerGVette Suspension - Brakes - Steering 0 04-16-2007 11:08 PM
