Th350 dirty fluid should i buy it? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-24-2010, 12:46 AM
Guys im looking at buying a used th350 {there not an off the shelf item in NZ so you kind of haev to buy used} its been sitting for about 18 months & the oils a little dirty. the case is clean so no suspect leaks .. Does the dirty oil mean it buggered or generally needing a service..
Thanks in Advance
Old 03-24-2010, 01:06 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks in Advance
Dirty fluid isn't good, but it might not mean the tranny is junk, either.
Smell the fluid. If it's been overheated (a sure sign of trouble) you will smell the tell-tail odor of bad fluid- it's unmistakable.
If possible, see if you can pull the pan and inspect what may or may not be in the bottom and the condition and contents of the filter as well.
You would need to come equipped w/the tools, fluid and filter/gasket to replace the originals with, should you not take it.
Good luck.
Buick T-400 trans blowing out fluid youngceez Transmission - Rearend 1 03-08-2010 04:49 PM
Fluid Won't Circulate REDSNAPPER Transmission - Rearend 2 04-14-2007 09:58 AM
TH350 Tranny Fluid Coming Out Filler Tube 67ssguy Transmission - Rearend 3 03-14-2007 09:17 AM
TH350 fluid flow in cooler Jmark Transmission - Rearend 2 04-27-2004 07:14 AM
TH350 Fluid Level 47willys Transmission - Rearend 6 11-03-2003 06:18 PM
