Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 04-25-2007, 07:10 AM
dawg's Avatar
dawg dawg is offline
NAVY VETERAN
TH350 speedo drive gear replacement
just so Im not gonna run into suprizes whats the procedure for speedo drive gear replacement?
I know the tailshaft needs to be removed and im sure the drive gear is slipped onto the output shaft.
whats holding it on etc.
Old 04-27-2007, 03:54 PM
dawg's Avatar
NAVY VETERAN
re: TH350 drive gear replacement
anyone have a clue?
Old 04-27-2007, 04:34 PM
junior stocker's Avatar
junior stocker junior stocker is offline
Drop the driveline.Remove the speedometer cable and drive assembly from the extention housing.Remove the extention housing.There's a small spring-clip slipped under the speedometer drive gear;depress the spring and slide the gead rearward and off the output shaft. Don't lose the spring-clip.Don't forget to use a drain pan. Reverse procedure to assemble. Anyone else?
Old 04-27-2007, 04:53 PM
DeathRattle's Avatar
DeathRattle DeathRattle is offline
Some Punk Kid
Originally Posted by junior stocker
Anyone else?
You hit it all. You may even want to bend that spring clip back a little for a smidgen more tension when you put it back on. I run copper RTV around the gear housing when I plug the speedo back in. Not a requirement but It helps me sleep at night.
Old 04-27-2007, 06:59 PM
Jmark's Avatar
Jmark Jmark is offline
HR moderator dude
There "may" also be a steel sleeve with O-ring on the output shaft too. It's for sealing the yoke when it's inside the trans. It slides off too. May take a little tapping but it's not usually on too tight.
Mark
Old 04-27-2007, 07:48 PM
Deuce Deuce is offline
CURMUDGEON / MODERATOR
 Deuce's barnstar
Wiki Edits: 5
This photo shows the clip ...
Now the photo is of a 700R4 ... not a Turbo 350 but the photo does illustrates where the clip is and how it works ...
Old 04-28-2007, 03:31 AM
dawg's Avatar
NAVY VETERAN
thks guys that a piece of cake!
Old 04-28-2007, 07:41 AM
Crosley's Avatar
Crosley Crosley is offline
Moderator guy
I hope you used the correct drive gear for the 700 trans.
A t-350 will fit , but is the wrong diameter .
If you can't fix it with a hammer, you have an electrical problem.
Old 04-28-2007, 08:07 AM
dawg's Avatar
NAVY VETERAN
nope I got a TH350
and if you math wizards can check my math for correct speedo gearing
27.1 inch diameter tire
tire revs per mile 768.0
3:73 rear ratio
speedometer calibrated at 1000 revs per mile.
I come up with a 7 tooth drive gear (on tranny shaft)
20 tooth driven gear (on speedo cable)
that will give a .50 margin of error.
Id rather the speedo read a bit high than low.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "TH350 drive gear replacement"
TH350 speedo gear color john69 Transmission - Rearend 7 12-12-2004 06:57 PM
TH350 and what happened to 2 gear? Fryksten Transmission - Rearend 5 02-25-2004 06:46 AM
Swapping Gear Drive Out for Timing Chain or Belt Drive - Need Suggestions horvath Engine 4 05-24-2003 07:47 PM
gear drive Buffed Engine 17 10-30-2002 12:28 PM
TH-400 Speedo Drive Gear Replacement 454impala69 Transmission - Rearend 6 03-17-2002 02:03 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
