Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - th350 fairbanks kit down shift problems
Old 07-31-2011, 09:32 AM
bink32 bink32 is offline
Originally Posted by Crosley
Vacuum modulator is there to blow off pressure in reverse. Reverse pressure can go over 300 if a aluminum plug is installed in place of the vacuum modulaotor
Sounds like this kit is similar to TransGo. The hole in the governor circuit should fix the problem. The hole plows off some pressure to allow the down shift to first
thank you ill give it a try!!!
