Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - th350 fairbanks kit down shift problems
Old 07-31-2011, 11:03 AM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Remove the valve body and drill the hole in the valve body. In the governor circuit at the rear of the valve body.
You installed the kit, I figure you know a little about the transmission?
