Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - th350 fairbanks kit down shift problems
Old 07-31-2011, 12:15 PM
bink32 bink32 is offline
Originally Posted by Crosley
Remove the valve body and drill the hole in the valve body. In the governor circuit at the rear of the valve body.
You installed the kit, I figure you know a little about the transmission?
ok got thanks i thought that just wanted to be sure it was there and not the case side thanks
