Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - th350 fairbanks kit down shift problems
Old 07-31-2011, 01:01 PM
bink32 bink32 is offline
Originally Posted by Crosley
Since I do not know how the Fairbanks kit is designed... and I doubt the kit is too different from a TransGo kit.
Is the governor used in the Fairbanks kit? Or is it eliminated?
Vacuum modulator used or removed?
My guess is the governor circuit is flooded and the trans will not bump back to first like it should. This happens in a TransGo kit install about 2 out of 10 times.
A hole is drilled into the governor circuit may help. About .065 size hole is a good size to start. Valve body removal is needed. Drill the hole in the circuit at the rear of the v-body is easiest
thank you again works like a champ !!!!!
